Whaler,
Apparently the 427 uses a different switch than the FIA. Mine is a 3 spade that is considerably larger than the one that matches the numbers you gave which is a 2 spade. BOB P. do you have numbers or cross reference for the FIA brake switch. Mine is an early FIA so it may be different than a later model.
David
What a waste it is to lose one's mind. Or not to have a mind is being very wastefull. How true that is.....Dan Quayle
