Old 06-03-2012, 04:39 PM
griffbl griffbl is offline
Cobra Make, Engine: Autokraft MK IV 302 Ford
Default Sorting Out Webers on AK1066....
Well, I did want to share my progress....I bought this Autokraft car recently, (I posted some of this under the Autokraft forum) and it was equipped with a Ford SVO blocked 322 equipped with Weber 48 IDA's that were simply not right! Lots of exhaust soot on the floor of the garage from the sidepipes, some popping in the exhaust, appeared to have some fuel washing the cylinders.....NOT right. I had never dealt with Webers. Process was frustrating as I got up to speed, as my mechanic had the car, he did not know Webers etc. Long story short, I enlisted the help of Jim Inglese and he helped me get it straight. Almost home! Only a little fine tuning remains....The frustrating part was ordering tools, ordering different jets, etc. and then the resulting delays.....I am not afraid of Webers any longer, and my mechanic is now quite good with them.
I thought I might share some of my experience so as to help future Newbies like myself! This will not be helpful to the many Weber experts on this forum!
A few tips:
1) Start with a properly timed engine! Webers like lots of timing. This has been said over and over again, but trust me, you will save yourself time, and money, by trying to advance your timing maybe a bit more than you had thought was necessary. We ended up on about 38 degrees total....more than it had before by a few degrees to be sure. HUGE difference in eliminating the popping in the exhaust. Some people had said that was a necessary condition of having Webers...NOT so!
2) Make sure you are running a good fuel regulator and gauge on your fuel system and that you are running proper fuel pressure (for my application 2.5-3 pounds)
3) Set your float levels FIRST so as to have a proper baseline from properly adjusted carbs. We actually re-built the carbs and replaced several small parts including mixture screws, etc. Some of the old mixture screws were BENT from being over tightened.
4) Referencing #3 above, we bought an excellent float adjustment tool from Gene Berg at [url=http://www.Geneberg.com] Great service, all good. I also bought a complex measuring device, very well made, from Bieker Engineering at bieker The latter is probably not necessary, but it will give you the float levels without having to tear down the carbs. Might be worth the cost depending on your situation.
5) Jim Inglese, as many others have noted, is a wonderful resource. He was very helpful to me and my mechanic. I paid him for some of his time, as I was not familiar with Webers nor was my mechanic when we started......money well spent. I purchase some jets from a large company before contacting Jim, and they bothched the order. (sent 4 jets instead of 8 and set us back another week because of the mix-up). Those mistakes do not happen with Jim. I did not post my exact set up yet, as it is not perfect, but 90% better than where we started.
6) My car had the black rubber, with steel mesh sandwiching a layer of foam, air filters on the stacks. The car was set up to run through them. They are AWFUL....DO NOT USE....The foam can deteriorate and fall into the car. Webers are very sensitive to these covers, and while I want a simple wire mesh screens, the former are to be AVOIDED.
7) Suffice it to say that my car was WAY lean, and the previous owner masked that condition by backing the mixture screws WAY out...this, combined with the screens made a car that simply popped, ran overly rich at idle, etc. I have only the slightest of stumbles now in the idle circuit that I will pursue now....
Hope this helps, and thanks again for all the tips from Clubcobra forum members...
Bradford Aka Griffbl
