Old 06-20-2012, 10:07 AM
Wisconsin_Snake Wisconsin_Snake is offline
Cobra Make, Engine: Classic Roadsters, 95 EFI 5.0
Question for you guys, are you using Factory fuel rails? If so what hose line are you running...
The Spring lock connectors that I have (OEM) are designed for 3/8 Nylon hose which means the inner diameter of the hose is .275. So if I try to connect a 5/16 rubber hose to it, it's loose on the barbs..
Are the SpringLock connectors you are using do teh barbs fit 3/8 rubber fuel injection hose?
