Old 06-22-2012, 11:10 PM
MaSnaka's Avatar
MaSnaka MaSnaka is offline
If you have adjustable coilovers just increase the ride hieght by adjustment of the springs. If your running the original coil spring set up, they are adjustable by screwing the upper spring perch up or down. There should be access to the top of the spring perch, which has a hex top, through the package shelf behind the seats. May be covered by carpet. Or new coil springs at a different length. Good luck.
John
