Thread: spring rates
Old 06-24-2012, 04:50 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
You also need to look at the size of your sway bars... the heavier the sway bar means you can back off slightly on your spring poundage...you need to get the right balance you need to look at the whole picture not just the pounds on the springs...Talk to someone with a similar car.....
