Check your distributor. If you have a vacuum advance unit it will have a pod attached to it with a nipple for a hose to attach to both the pod and your carb. If no pod, then you don't have a vacuum advance setup on your distributor or it is capped off by a rubber cap rending it inoperable.
My guess is you only have mechanical advance on that engine. I don't think that carb even has the outlets to connect a vacuum advance line if you did have a vacuum advance dizzy.
Jim
