Old 07-19-2012, 11:51 AM
DAVID GAGNARD's Avatar
Using the cutter from the above posts,it is not neccessary to wrap the hose at the cut,the way the cutter is made it "pulls/bends" the wire ends inward....
makes it very easy to install, that's why I quit using other methods of cutting braided hoses and went to this cutter....
Although the tape is not needed, it will not hurt to use it and is a good idea for someone that has not used this type of tool much....
David
DAVID GAGNARD
