Old 07-28-2012, 09:49 AM
knelson knelson is offline
Cobra Make, Engine: ERA #266, 427 S/C sideoiler stroker, pin drives
I have a holley 7lb. electric fuel pump (w/no regulator) mounted just above the front of my fuel tank bolted thru the rear of the trunk. There is a thin piece of rubber between the pump bracket and the body. I had no problems ever with fuel flow until just recently it weakened causing stall out under hard acceleration. I just replaced the same pump because it lasted me 21 years!
