Old 08-21-2012, 11:07 PM
Cobra #3170 Cobra #3170 is offline
Default Jerrico
Originally Posted by spookypt View Post
Hi all, I'm after some feedback based on user experience...
Re: Downshifting a Jerico 4 speed box.
What I want to know is what works best? I understand that the BEST shift style is double clutch, heel toe and throttle blip under braking etc. Obviously this all needs to happen fast and at the right rpm speeds. I'm not a pro driver.
If this all can't be managed a regular change with throttle blip is nearly as good. I've been advised the faster the throw change the better.
I emailed Jerico in the USA and regarding the way they best recommend to downshift their boxes and their response was...
"Press in the clutch, and select the required gear."
That was it. One line. So I qualified their response by asking......
So Jerico, you're saying that I do not need to double clutch or blip throttle on down shift?
Response
"yes"
Their customer service for a reasonable question about their product was pretty poor.
I then rang their Australia Agent. Now there's a difference. The bloke spent 20 mins on the phone with me and said that at my next track event he'd drive down and come and have a look at what i was doing and he'd share his experience.
Based on that response alone I've booked the box in for strip down and refresh at the end of the season.
Anywho, tell me your experiences please.
Spookypt
Give a slight throttle lift pull the lever from whatever gear you are in to neutral the engine will spin the gears up (you can blip the throttle too) and put in the gear you want quickly, no clutch involved.
