Old 08-26-2012, 09:45 PM
WardL's Avatar
WardL WardL is offline
Cobra Make, Engine: SPF #2608, Roush 427SR T-W
I have managed to replace both rear wheel bearings! I had to buy a new hub for the left side. The left hub was damaged and I used weld overlay to build it up and had it turned down to specs. The heat must have shrunk the hub and it wouldn't go on the axle. Got a used replacement hub. I ruined one green bushing on the upright lower shaft. The green bushing I ordered from Hilbank seemed to be a little too big and was a bugger to get on. The end result seems pretty good so far. The noises went away! The bearings were made in Germany. Thanks again for all the help from Randall Thomas and Mike Mitchel.
