Old 08-27-2012, 09:09 AM
jualwatt's Avatar
jualwatt jualwatt is offline
Cobra Make, Engine: Backdraft 1134, Roushcharged Coyote Aluminator NA
You will not be dissapointed with the coyote. Just note that the stock coyote can produce 390+ ft*lbs of torque. Mine has been awesome so far with just over 1k miles. I used a TKO600 and set the rest of the drivetrain up to add a supercharger later just in case I have a desire for more (have the coyote aluminator NA with 11:1 compression, so would run at a low boost). I also used 3.91 gears in the rear and with the .64 5th gear OD run about 2k RPM at 65 with 295/40 18's.
Have fun and let everyone know what you think once you get to drive it. Not a 427, but still alot of power for a light car!
