Old 08-27-2012, 08:16 AM
jualwatt's Avatar
jualwatt jualwatt is offline
Cobra Make, Engine: Backdraft 1134, Roushcharged Coyote Aluminator NA
One other thing to look out for with the coyote set-up: the airflow sensor is very sensitive to air turbulence. Blowing the dust off I notice the engine stuble if the air stream came close to the filter element. Look around to see what you can find, but Backdraft does have the air intake tube with airflow sensor mount point available, but you will need to isolate the element form the airflow through the radiator (mine has a shelf over the radiator which the air flows under so as not to disturb the sensor).
