Old 09-12-2012, 03:24 PM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
So the Gates belt is 37.5" and the Goodyear belt that I'm running is 38". I tried using a little pry bar for leverage, but I couldn't get the adjustment bolt back in (wasn't even close).
Steve, instead of messing around with the wheel well, you might want to look at the bracket and see if you can slot out the adjustment hole. I was thinking about doing that before, but to do it right you'd have to remove the bracket.
Doug
