Old 09-13-2012, 06:15 PM
patty442 patty442 is offline
Good evening. They were not plumbed in parallel in case one failed. In general, only one was installed on most of the race cars in the beginning. The S/C also. The mounting bracket was on the frame in the early run of 3100 street cars also. Might go out further in production. The two reasons why two were used was first, the mounting and plumbing was simple and direct, the bracket lent itself to back to back mounting easily with room for the additional pump, but second, and more importantly, by using two pumps in parallel not in series, the volume of circulation was almost doubled without an increase in pressure. Pressure was not an issue, nor desirable. More volume for the circulation was the desired result, which was accomplished by two of the same pumps. I have seen black cap hi performance models, and blue dot versions of original Bendix pumps on unrestored cars in the sixties and seventies. All with quite small 1/8 NPT female fittings. Then came Elmira pumps still quite close and finally the current Facet pump is pretty close, except for color, clamping, label, and wiring. Mounting bracket is also a little off but still quite good for the average Cobra lunatic. Hope this helps. Be careful studying 3015. But don't get me started .That's a whole another story. good by to all for now.
