Old 09-19-2012, 06:46 PM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
Originally Posted by Wazza View Post
After these ...I HIGHLY recommend DART blocks....the old standard windsor blocks don't like the stresses caused by the lateral "swing" of the stroker crank.
Warren.
Ford built a factory stroker windsor motor based on the 5.0 block. I've owned 2 of them now. They used a 3.4" stroke crank on the standard 4" bore for 342 cubes.
The factory fitted a main bearing girdle to strengthen the block and they are a fairly low reving beast, Rev limiter on these motors is set to 5750RPM. Probably to help the motor live and so they can give it a factory warranty.
Ford made a promotional video on the engine build at the time.
Mike Murphy
Melbourne Australia
