Old 09-30-2012, 10:53 AM
Hydramada Hydramada is offline
Originally Posted by 347stroker View Post
Guys I have 12 led turn signals on my tractor trailer (it's good to be seen) and they don't overload a flasher. They don't create enough resistance to operate a mechanical flasher. Just go to your favorite parts store and get an electronic flasher. Tom
Actually, even with the electronic flasher, you cannot do all the bulbs without adding diodes in line. It seems there is enough bleed from the single indicator bulb on the dashboard to cause all four lights to blink if they are all LEDs. Just buy an electronic flasher and replace the 4 bulbs in the rears for a quick and easy upgrade to your rear lighting.
I did the (2) 1157 and (2) 1156 bulbs in the rear of 1867 and am very pleased. Oh I also swapped the bottom and top sockets to put the brake in the larger reflector.
