10-08-2012, 05:23 AM
KY
Generally the use of coatings is used for friction reduction and anti-wear benefits.
The two spots where I see expansion the most on an aluminum block combination is in main bearing clearances and valve lash. I run about .0005-.00075" tighter bearing clearances on the mains. On the valve lash, solid cam engines get about .004" more tighter lash when cold and hydraulic lifter engines get a tad more lifter preload.
