Old 10-14-2012, 07:45 AM
patrickt patrickt is offline
- but not sure.
If you have the slave bleeder screw open, and the tube on the bleeder, going in to a jar you can't miss telling that the master cylinder is squirting a nice flow of fluid when someone pumps the pedal. I mean you really can't miss it. It will be as plain and obvious as the nose on your face and that will tell you that the master cylinder is working right. If you can't get that far, then the problem is "upstream" from the slave cylinder.
