Old 11-09-2012, 11:01 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Rick Parker View Post
Shut engine off and look in throats of Driver side carbs. Is fuel dripping onto the throttle plates. While running, are they drawing the same amouint of air (as the pass side?) Are they syncronized?
+1.
How long since the carbs were last synchronised?
Things to check: absolutely ZERO slop in the linkage, float levels are correct, all cylinders draw the same volume of air, all mixture screws are out at 3/4 turn.
Gary
