Old 11-11-2012, 03:51 PM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
That's right. I'm thinking of going with a 9" 250 lb. spring. I need to determine this shock issue first. Either fix the mounting points or go with a shorter shock. With the shorter shock I could cut the bump stop 1/2", put in the stiffer spring and have more travel. It would be nice to learn why I have to do this. Wrong mounts or wrong shocks?
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
