In my opinion -3 Works fine. Been using it for 25 years no issues? No need to reinvent the wheel. The only variable is the actual amount of fluid volume being moved back & forth. The same ratios in sizing between Master/Slave fluid transfer to achieve sufficient movement of the clutch arm CAN be obtained with various sizes and still create the same pedal effort.
Rick
