Old 12-18-2012, 04:50 PM
vector1 vector1 is offline
Cobra Make, Engine: jbl
initially a little lube on the threads and flare help. work the joint to let the flare portion become accustomed to each other, like 5 lbs then release, 6 or 7 times, then the last one maybe 10 lbs. lb.'age amount is just an example. shouldn't take much to make it seal, this also works good for brake fittings.
