Ok...I might have to call you on that one for an in-hand walk through
I took my striker off because the nut just will not tighten and their is a lot of play in the striker. Is the striker supposed to freely move around or is it supposed to be fixed and solid?
The striker itself looks stripped to me...the first 3 threads are flattened out a bit. I inherited this issue when I bought the car. I was told I had to "really slam" the door. Well, I just don't believe I have to do that, so I took it apart last night.
If I need more shims or a new striker, are they readily available without buying the whole assembly?
Thanks for your time.
