I was thinking that if its both sides have residual pressure then maybe MC (not pistons). Do you have a bleed valve on the MC to do the test you did at each Brake Caliper/piston?
Master cylinder pushrod is too long, covering the compensating port in the master cylinder.
Gary
This MC has been fitted for a while.....no problems up until recently.
Gregg
No bleed at MC, only way is to crack the line to either front or rear.
