Old 01-20-2013, 06:37 AM
Jethrow's Avatar
Jethrow Jethrow is offline
Cobra Make, Engine: FFR Mk4 Roadster, LS3, TR6060, 8 3/4"
Default Back with more questions
Hi everyone,
thx again for all your help in the past and if you don't mind, I need to ask for assistance again.
The wiring is getting there I think (and doing my head in!) but I need to check a couple things with you all.
Firstly, the LS3 starter motor.
Looking at the above picture I guess the green arrow is pointing to a connector that the start wire from the key should run to. Is this correct? If yes, any ideas on where I can get the matching male connector?
And while we look at this pic, does the yellow arrow point to a possible ground location? If yes, should I be connecting to it? I have earthed the motor to ground from a bolt in the block just in front of the starter - is this sufficient?
Moving to the next picture, this is of a connector (purple arrow) that is on the right hand side of the TR6060 gearbox towards the front. This photo is taken looking up with the front to the left.
I am guessing (hoping) this is the reversing switch. Can anyone comment on this and if it is, can anyone advise as to where to get the matching connector. Also, with regards to wiring thru this switch, I am guessing it is power to switch, then continue down and thru the reversing lights, then to ground. Does that sound about right?
And to the last photo, if we look at this connector (yellow arrow) can anyone confirm it is the vehicle speed sensor.
I think it is because the plug on the loom marked speed sensor fits there, but I want to make sure. This sensor is up the back near the gearbox output, right hand side.
Many thanks again.
Tim
FFR Mk4 Roadster
HSV Clubsport R8
