Old 01-28-2013, 07:26 PM
Cobra #3170 Cobra #3170 is offline
Default Pins and Clamp load
Originally Posted by Rick Parker View Post
If anyone thinks that the drive torque can be transfered only by the clamping force against the hub then I say remove them, use 1/2" diameter counter sink machine screws to hold the hold the adapter to the axle flange and save the weight! If it could be done, the F-1 guys would have devised a way to do it long ago. The studs, pins, or sleeve nuts are in shear and transfer the twisting torque to the wheels. The first 289's had splined adapters the splines ultimately were deemed insufficient when HP and torque were increased and the studs were adapted from other racing fitaments. You couldn't clamp the wheels tight enough otherwise. Any takers?
I know of two recent cases where the drive pins on a Cobra were sheared off because the knock off was either not torqued properly or there was lubricant on the mating surfaces. You need the pins and the clamp load to retain the wheel.
