Old 01-31-2013, 05:35 PM
ERA Chas ERA Chas is offline
Cam is ordered...
Went with Bullet Cams as I couldn't find the lobes that I really wanted from Comp. It's a billet solid roller, 260/265 @ .050", .714"/.694" gross lift, 109 LSA on a 105 ICL.
Heads are TFS Twisted Wedge R heads, which are going to get some 2.100" valves to help out in the flow area. Intake is an Edelbrock Super Victor.
Tasty cam B2! Are the heads better than 330 @ .600"?
If so you should really try a 1050-at least on the dyno. If you get near 700 (I think you will if the heads are 360 to 380) get Gary to use a taller scoop.
Think E'brock makes a 4500 single plane for it-cut the pad as much as you can.
We got 700+with our 18 degree heads (380 cfm) and 725 with CHI 3V's on our 427's and 460's.
Chas.
