Thread: Power Steering
Old 02-08-2013, 02:40 PM
Ryder Ryder is offline
Originally Posted by Modena View Post
Mike I'm guessing you will need to take 1mm (total) off the double D. The round-tube CR uses the VP rack, and with the Uni that Ian supplies it requires taking 0.5mm off each side of the flats of the D
Ben
It's the same with the Harrison and using the VR rack - it needs 0.5mm off each side.
It's pretty hard material, and I'm wondering if it's worth the trouble machining such a small job? I did mine with a second cut file with a safety edge, using a vernier caliper to keep it bang on square, didn't take long and theres no need to take the rack apart.
