Old 02-24-2013, 04:06 PM
blykins blykins is offline
You spec the bearing/bushing for the clutch.
If you're running a really aggressive disc, such as a sintered iron or similar, the dust will actually wear a bronze bushing over time and you'll get slop there.
For really aggressive clutches, it's best to use a bearing.
For factory style discs, like an organic disc, you can use a bushing.
Make sure you dial the bell in, or you can get a worn bushing/bearing as a result.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
