The upper trailing arms (Hotchis) came with the urethane bushings for the upper diferential mounts. I replaced them and have no issues. The bushings only dictate the movement/slop. You should use a grease of some sort on the bolt for it to rotate in the metal sleave that is in the center of the bushing. I used graphite on my bolts.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
