Old 04-03-2013, 03:41 PM
SSSammy's Avatar
SSSammy SSSammy is offline
Originally Posted by Varmit View Post
Just got off the phone with Tony at Keith Craft, ordering my 482. I'm a little undecided on cam selection. Car probably will not see the track, but does get some canyon running, and street play. I want something that really hits at idle, but do not want the bottom end so soft and full of surge that it is a big problem at low speeds. We discussed selecting a cam of about 242/248 on a 108 LSA. What do you guys with 482's run on the street. Want something in the 625 to 640 tq range on the street
Thanks
Benny
Benny, I have such a motor rebuilt by KC last August (after a rather dramatic rod bearing failure on the track). New Pond Al FE block, 482 stroker steel crank, H-beam rods, blueprinted oil pump, and 10 qt AVIAID pan. They put in a 242/248/110 roller cam, redid my Edelbrock Stage II heads, Erson roller rockers. It makes 591 hp at 5600 rpm. 604 tq. It has a 750 cfm Holley 4150HP.
Nice mild street motor (compared to some of the 482s). I think the compression is about 10.5:1. But ... these FE's are still beasts, and if you want all the HP/TQ you are talking about, you really don't have a street car. It will be an amusement park ride for sure Suit yourself .. I would not change mine, but do take it to a track before you take it to the canyons
Just fyi, mine does not run smoothly below 2000 rpm. So driving at low speeds in parking lots, away from a stop, etc. requires a lot of clutching and reving to keep the motor spun up. It comes up on the cam at about 3000, then it had better be pointed straight! I really could not use any more HP, the tires won't stick in any gear as it is. Soft tread compound is your friend No street tires, use Billboards, Avons, or (Nitto NT01's if you have 17" rims). Good luck!
Sam
