Old 04-28-2013, 01:11 PM
DanEC's Avatar
DanEC DanEC is offline
Default Shift arm shaft seal leak
One of the shift arm shafts is leaking slightly on my rebuilt Toploader transmission. My main concern is I'm getting a leak and I haven't even driven the car yet - only run it in neutral. At first I thought I might have over-filled the transmission but the fill port is considerably below the shifter shafts so I guess igear lube is getting thrown up on the fork and shaft and dribbling out.
Is there a seal on the shaft that is replaceable without major dissassembly of the transmission? It looks like the shafts screw into the forks so I'm assuming I might have to pull the cover and unscrew the shaft.
