Old 05-06-2013, 08:44 PM
PeterAllen's Avatar
PeterAllen PeterAllen is offline
Cobra Make, Engine: Puckett 250 GTO - LS1
Default Holden ABS info required - Thanks
I'm trying to use as many parts from the one donor car (VZ Ute) as possible and that includes the brake booster and m/c. I have them mounted but as I start to make the hard lines I'm unsure which ports on the m/c are which. I took photos as I pulled the donor apart but I don't have one of the top of the ABS unit which, if I recall correctly, was stamped 'front' and 'rear'.
Can someone with access to a late model Holden with ABS look to see if the ports marked #1 and #2 in the photo have 'front' and 'rear' stamped near them, and, which ports on the m/c the lines are connected to. Thanks.
