Thread: Weight
Old 05-08-2013, 04:32 AM
strictlypersonl strictlypersonl is offline
The most important part of the front unsprung weight is the wheel and tire.
If you have pin-drive wheels, there isn't much that can be reduced without creating a safety issue. If you have bolt-on wheels, I've found an aluminum Wilwood hub and hat that probably saves a few pounds. I've only worked out that system for the big brakes so far.
