Old 05-14-2013, 03:26 AM
Default Angle way off from trans to rearend
Mike Sears sell a digial level gauge for about 30.00 buck. You need to add 1/4" to 1/2" spacer between the mount and bottom of the trans to get the driveshaft parallel. Hand brake cable doesn't run inside the drive shaft loop unless Bob P at ERA has changed the routing of it. You need to have the rearend setup first to get a little angle of this pinion up and then have a trans tilt down to offset the angles. Want "0" if possible. ERA sets the motor off set in the frame 1" to the right, don't worry about this. Rick L.
