Old 05-14-2013, 04:49 AM
strictlypersonl strictlypersonl is offline
Mike,
Shim the transmission mount so that the centerline of the transmission output is 3.5" above the plane of the chassis X member. You shouldn't have the driveshaft parallel to the transmission axis. That will cause premature wear in the driveshaft bearings because they end up not spreading the load over more area when they "work".
With the ERA rear suspension, the pinion angle should be correct without any "adjusting". Just install shims between the bottom mount and the rear crossmember so that the bottom holes line up correctly.
Do you have the emergency brake balance assembly? (page 79 of the latest manual) It is installed under the driveshaft safety hoop. It keeps all the cables safely out of the way of the driveshaft.
