Old 05-15-2013, 08:22 AM
400TT's Avatar
400TT 400TT is offline
Default PACE 427 Unveiled
For those interested, some detailed information on the PACE 427 since it is now in full scale production.
Base Kit $29,995 (contact us for full packing lists)
Comprehensive Kit $48,995 (contact us for full packing lists)
Limited time specials avaiilable e.g. Base Kit comes with free Brembo Brakes & Rotors, Free Custom Gelcoat Colours, Free Upgrade to Carbon Enhanced Body etc.
I will post photos and details on the different aspects of the car as time allows.
First the CHASSIS...
SPECIFICATIONS AT A GLANCE:
  • Aluminium Semi-Monocoque Design
  • Approx. 100kg total weight
  • Just under 9000Nm/degree Torsional Rigidity
  • Premium Aluminium Sheet Grades & Custom Extrusion Materials
  • Full Flat Floor Design - nothing is below the floor, including drivetrain, underbody exhaust etc.
  • Supports both hidden underbody exhaust and side exhausts.
  • Removable Body
  • Bolt on engine & gearbox mounts to allow flexibility of mounting options, drivetrain choice and ease of change/upgrade
  • Aluminium inner guards, radiator support/shroud & undertray
  • Built in mounting points for drivetrain, suspension, steering rack & column and lots more...
  • Wider Drivers Footwell
  • Accomodates very tall & very large drivers, 6'5"+
CONSTRUCTION METHOD:
  • Fully Computer Designed & Optimised
  • Pulse TIG Welded with Miller Dynasty 350 Machine
  • Built Using Full Rotisserie, Adjustable Bed Jig
  • Material CNC Cut & Folded
  • Gussets & Reinforcement Structures in High Stress Areas
  • Chassis has integrated self locating tabs/slots to aid construction ease and accuracy
  • Chassis continually assessed for accuracy/consistancy during construction
TESTING METHOD:
  • Computer Based Chassis Torsional Simulation Tests - within a few percent of accuracy to physical tests.
  • VSB 14 Spec Torsional & Beaming Tests
  • Laser Aided Measurements for Accuracy
  • Computer Simulated Von Mises Stress & Safety Factor Tests
Please post feedback and if you have any questions or comments.
Enjoy the photos and information.
www.absolutepace.com
