Old 06-29-2013, 06:41 PM
Shootnride's Avatar
Shootnride Shootnride is offline
Cobra Make, Engine: Superformance, 427SO
Default Help With SPF Dash Removal
Good Evening,
I recently purchased a used SPF car that needs a little TLC. I need to drop the dash enough to work on a couple of gauges and clean up a couple of things that were done by the previous owner. I was hoping to tap into the braintrust of this forum before I go tearing into the dash. I only see three attachment points for the dash but it appears that the drivers side can not be lowered as the steering colum is tight against the top of the opening in the dash. Are there any tricks you guys know of to dropping the dash to gain access to the back side ?
Appreciate any input. Thank you.
Ted
