Old 08-02-2013, 09:14 AM
rodneym's Avatar
rodneym rodneym is offline
Full Blown Member
Premier Contributor
I finally got the fuel log installed last night and also made a new braided line with fittings. Now that I can make braided lines the perfect length the first time, I probably won't need to make one again until I forget!
[IMG][/IMG]
BTW, I got the rubber fuel line (off the log, to the carb) to not crimp. I put a piece of Stainless Steel spring inside of the 3/8" line, keeping it from collapsing. Now the effective inner diameter is roughly 5/16". The coil probably isn't good for the best flow BUT wouldn't you say it's better than crimping? Thoughts?
rodneym
