Old 08-02-2013, 01:39 PM
dcdoug's Avatar
dcdoug dcdoug is offline
Originally Posted by rodneym View Post
BTW, I got the rubber fuel line (off the log, to the carb) to not crimp. I put a piece of Stainless Steel spring inside of the 3/8" line, keeping it from collapsing. Now the effective inner diameter is roughly 5/16". The coil probably isn't good for the best flow BUT wouldn't you say it's better than crimping? Thoughts?
I had the same problem, but if you buy higher quality fuel hose, it shouldn't crimp. I found this Goodyear hose works better than some of the others and the radius from my fuel lot to my carb is a lot worse than yours......to fix it though I'd have to cut the brackets off and re-braze them, wrecking the coating, etc and I don't really want to do that.
http://www.summitracing.com/parts/gtr-65123 (this is 5/16 line)
www.partskeeper.com
