Old 08-24-2013, 04:43 PM
patrickt patrickt is offline
Originally Posted by lippy View Post
Patrick - So reading through that post it appears you're using a Holley 4160 750 CFM and a "drop" air cleaner mount. And with those, you have almost 3/4" clearance (minus the height of the top of the nut). Did you mill down your intake, or is there anything else there I should know? Thanks for the help.
No milling, and "yes" it's a Holley 4160 (3310-11) and the air cleaner base is flat, as per the pics. If you guys need any measurements, just ask and I'll walk out to the garage and get them for you.
