Old 09-08-2013, 08:01 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Here comes a debate:
John if you are talking about windwings, are you talking about using the original bolts that hold the frame sides on?
Just wondering because those screws are usually drilled through the "up-rights". No way to hit the glass on those.
I thought you were actually talking about the "Visors". The Visor attaching screws are usually the ones that will contact the glass and cause it to crack.
The wings should have come with set of 10-24 screws with acorn nuts that will fit the screw when it is put through the side posts.
DV-
