Thread: shock advise
Old 09-17-2013, 07:11 AM
Zedn's Avatar
Zedn Zedn is offline
Pills what size and rate are the springs you have? I need some for the rear as the ones i have are too soft.
Does you car use the jag front cross member or just the control arms. I think only RCM and David Tucker kits use the full cross member / subframe.
Rob, when you say bump stop rubber do you mean the rubbers on the upper control arm? Mine do not sit on the subframe.
