Old 09-20-2013, 11:18 AM
FWB's Avatar
FWB FWB is offline
Originally Posted by trularin View Post
Should you need it, in my gallery is the schematic of a ford. I think it is thunderbird. It shows the factory connections for that alternator.
One test I do is to get the car running and then pull the battery cable. If the car dies, the alternator is not working.
With the number of experts that are or will reply to this thread, I am sure you will fix this quickly.
Did you test the unit after the rebuild?
Tru
the pic i posted was from a 66 bird shop manual. the transistorized voltage regulator is a little different, but he posted non-transistor connections for his so......
using the idiot light with a ammeter is not something i have done so i'm not sure if when it lights is that an indication of a non-charging condition or not. A meter on it when running will surely be the way to go..
Fred B
