Old 09-25-2013, 11:16 AM
Keithc8 Keithc8 is offline
Default FE aluminum blocks options and pricing
Shelby has a few blocks available right now and wanted to give you guys some pricing. Standard bore stuff that is about 4.245 to be finished honed to 4.250 are 6195.00 and the big bore stuff is 500.00 more. The head studs that you will have to use are 285.00. This is a discount to our normal prices. Shelby retails the block at 7195.00 and the studs at 385.00. You will have to do your normal finish machining on the blocks.
Pond blocks are 5195.00 and come in 4.240 to be finished to 4.250 or can be bored up to 4.310 if you would like. The head studs for the Pond block run 250.00. Same as the Shelby all normally block finish work will need to be done. If we can help you with any of your aluminum block needs just let us know.
Thanks, Keith Craft
870-246-7460
Keith C
