Old 10-15-2013, 08:05 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
The neutral safety switch is on the transmission. The wiring for it comes with the chassis and a jumper is installed by the factory, bypassing it. It feeds up to the Start Inhibit Relay which prevent you from starting the engine when the car is in gear.
Contact me offline with your electrical issues if you like. We'll work thru them. Exactly what are your charging issues and chassis number? One wire or 4 wire alternator? AMP meter or Voltmeter?
SPFWiringDiagrams@Comcast.net
