Old 10-15-2013, 09:13 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
It's located behind the dashboard, roughly in the center of the dash, grouped with 2 other relays. IF yours is all original back there, the silver relay is for the headlights, one relay is for the fans (it has a BIG red wire on it) and the third relay, with all the green wires, is the start Inhibit relay. All three relays are zip tied individually to connectors on the back side of the dash. The terminology for the relay is all relative.... What "drawings" are you referring to? What Superformance Wiring Diagram are you referring to?
Good Luck........
SPFWiringDiagrams@Comcast.net
