Old 11-28-2013, 07:40 AM
madmaxx madmaxx is offline
Slow down. none are perfectly centered. If you don't have the poly mounts install them first. the only time a wedge is needed is if the pipe does not run parallel to the body. if you want to spend money give me call and you can send me a check. 99% of the time with stock pipes it just requires a flat shim under the motor mount. the wedges will make a drastic change and have never seen a wedge required to "center" the pipe in the hole.
Originally Posted by ha_pe_1968 View Post
Hi!
Have the same problem..the left side is perfectly centered but the right side is lower as it should be in the openening. So the wedge spacer could be the solution. Do you have any pics of it and an idea where i can buy it?
Thanks a lot!
Peter
