Thread: aftermarket ecu
Old 12-19-2013, 06:37 AM
olddog olddog is offline
Originally Posted by velj1 View Post
thanks alot guys, im currently looking into getting the ls1 ecu hopefully that works i no one of Melbourne LS engine specialist, they have made some of the most powerful holdens in Australia, iv spoken to them and they are more then happy to give it a tune if i can get the ls1 ecu fitted exciting times ahead
I would assume you will have to change every sensor on the engine to a GM type. I'm thinking GM may use a different Ohm range injector, so you may need to replace them too. You may have to go to coil on plug, as I do not know how you could make it work with the Ford distributor.
Good luck and let us know how this is done.
