Old 12-26-2013, 11:24 AM
Cobra #3170 Cobra #3170 is offline
Default Surge Tank
Originally Posted by bobcowan View Post
That's true. A lot of weight, cost, complexity, and failure points. If you need one, build it. If you don't..........
You are all correct, lots of complexity and some extra weight, but if your Cobra
handles well enough there no other option. A carb will flood or cut out and fuel injection needs a constant flow of relatively cool fuel. Drag racers don't run fuel coolers for no reason, so putting pumps and tanks in the engine compartment is not a good idea.
